Zabbix is an open-source monitoring software tool for diverse IT components, including networks, servers, virtual machines (VMs), and cloud services. Native integration with Morningstar-SNMP-enabled devices and our EMC-1 accelerates the setup process. Zabbix will automatically query the devices for many variables such as battery voltage, temperature, device state status for every minute. If a specified threshold is reached or an abnormal value is detected, the system will warn about it via an email, SMS, or other notification channel specified in the configuration.
https://www.morningstarcorp.com/software/zabbix/
More details on using Zabbix with our devices can be found in the technical document linked below:
Should you have questions regarding connecting with and setting up our controllers within Zabbix it is recommended contacting Zabbix directly for technical support:
